Mk3s+ Prusa connect
When moving hotend on a heatbed map, motors are coliding with each others direction. Needs beter tuning, it works however sound like the printer will fall apart.
Postato : 01/03/2024 6:40 pm
RE: Mk3s+ Prusa connect
Hi, this should not be caused by PrusaLink. How are you connecting the raspi to the printer? I hope you are not powering the Pi while having it connected to the einsy pins. Can you share more details please?
Postato : 07/03/2024 9:55 pm
Topic starter
answered:
It's your programming your x and y moves it same time 😉
Postato : 08/03/2024 9:18 am
It should do that tho, it does that when printing as well. If it vibrates excessively, you might have a bearing / rod alignment issue. Check if your axies are sliding smoothly. If not, you can always ask support to help you get the printer to a better operating condition and prolong the life of its components as well.
Postato : 08/03/2024 6:11 pm
1 persone hanno apprezzato
