Job printed but remains in the queue
Stránka 1 / 2
Rinho
(@rinho)
Hello,
I know use Prusa connect everytime to send job to the printer
Not sure yet about the exact context but from time to time the job is printed but stays in the Prusa connect queue and if I click on "printer ready" this job is started again.
It is possible this happens when I choose "printer ready" from the printer itself and not from Prusa connect, but not sure.
firmware upgraded this morning, issue still present, I printed 5 jobs today and had this twice.
During one of these printing, I saw the job was twice in the queue, but the second get vanished once the first has been finished.
Weirdo, maybe I don't pay enough attention to something but in case somebody else had this...
Napsal : 01/05/2024 5:28 pm
5 lidem se líbí
MikeM
(@mikem)
RE: Job printed but remains in the queue
I am having the same issue.  Though I am not sure it is not doubling the job the moment I click the "set ready" button.  I suspect this because when I look at the print queue timeline on the "print queue" tab it already shows a repeat of the same job projected to print as soon as the first one is done.  It doesn't do this for the other jobs on the schedule, but once a new job gets to the top of the list and "set ready" is clicked, it starts printing the job and adds an additional to the timeline.  I guess that's the same as your problem, just stated in a different way.
For me, it started after the latest FW update.  Perhaps it is because the jobs have new names "Print job ###", and doesn't delete the original name matched from the queue or something.   But, of course, that's just a guess without the code to see.
Regardless, I second the issue.
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4) - Prusa MK4 with WiFi built in
PrusaLink version - ?
Printer type - MK4
Printer UUID (you can find it in Printer detail page - address line) - bffc15cc-83e5-4eb5-8b63-696d6c8e37bb
Printer firmware version - MK4_MK3.9_firmware_6.0.0.bbf
PrusaSlicer version (if applicable) - PrusaSlicer-2.7.4
Description of the bug, including steps to reproduce (if possible). - As described.
Napsal : 04/05/2024 12:53 am
1 lidem se líbí
Scott Gartner
(@scott-gartner)
I submitted this bug a while back.  It just happened to me again tonight, it added the previous print to the queue all by itself after I started a newly uploaded print manually at the printer.  I have never used the queue and I was paying close attention, checking the queue every time I uploaded a file to see if it erroneously added it to the queue (I only ever selected "upload file").
Napsal : 01/06/2024 8:58 am
2 lidem se líbí
Flynny75
(@flynny75)
This happens almost every time for me. I slice, click 'Send to connect', select the (single) printer that I have, and see 'Add to 2. position in the queue'.
When I look at the print queue the previous, successful, print is still in the queue. Setting the machine ready consumes that same job again.
Print queue is useless for me because of this. I find this incredibly annoying.
I hope this is related to alpha firmware 6.2.0-alpha2, and it will be fixed in the next stable (whenever that is, its concerning there have been no further updates in almost 3 months now)
This post was modified před 1 year by Flynny75
Napsal : 23/12/2024 10:31 am
Rinho
(@rinho)
Actually it never happened again to me since then
Napsal : 24/12/2024 1:12 pm
psychlore
(@psychlore)
Also experiencing this about 50% of the time... can't rely on the queue since it's never correct, unless I manually delete things from it.
Napsal : 06/01/2025 6:15 pm
Flynny75
(@flynny75)
Coincidentally, this has been much more reliable since I replied a month ago, it makes slicing multiple plates and adding them to the queue actually functional now, which is nice
Napsal : 19/01/2025 12:30 am
will.barley
(@will-barley)
I experience this every time.
My workflow: slice, send to Connect, select my one printer, Add to print queue or Skip Queue
Every time a print completes, it remains in the queue.
Napsal : 25/01/2025 5:58 pm
Flynny75
(@flynny75)
I was mistaken in my jubilation earlier. This is still an issue for me also.
I slice, send to connect (queue is empty, print now), it finishes, and while the printer is on the '100% print finished screen' the job is still in the queue, with the message 'The printing time of the last job is unknown, the following jobs will not be displayed', even though the timeline indicates the job has finished.
If I set the machine as ready it prints it again, which is obviously rubbish.
Is there some network wobble that is stopping the printer from telling Connect it's finished? I'm using Eth so it's not a WiFi glitch.
Napsal : 06/02/2025 12:20 pm
Flynny75
(@flynny75)
After starting a job and leaving it for a some unknown time, checking back in Connect and I can see that the same item is in the print queue again. So it seems that its not the printer that isn't indicating the print is done, somehow Connect is just adding it to the queue twice. This should be easy to spot, where is Prusa support?
Napsal : 06/02/2025 8:39 pm
schmelzi
(@schmelzi)
Same issue here with FW 6.2 and before.
Napsal : 11/02/2025 10:28 am
Flutelab
(@flutelab)
Same problem. Prints stay in the Print queue (who needs it?) after they are finished. Please let us switch off the print queue, most of us dont need it.
Napsal : 03/04/2025 2:53 pm
MikeM
(@mikem)
At the risk of premature celebration as happened to @Flynny75, the queue has been working for me lately.  I have upgraded from MK4 to MK4S, and have updated firmware and Prusaslicer whenever those come out, for context.
I hope it stays reliable, but it has worked and then not worked again before.
Napsal : 03/04/2025 8:15 pm
thatOBS
(@thatobs)
I run a print lab with a MK4 and Prusa XL (5T), and this seems to be a consistent issue with the Prusa XL, but not the MK4.
I have to tell my users to be mindful of jobs in the print queue, to ensure filament is not wasted on redundant prints.
Is there any indication that the issue has been acknowledged by Prusa or if a fix is in the works?
Napsal : 11/06/2025 12:12 pm
Duck
 Duck
(@duck-2)
This is still an issue. I'm getting really tired of the printer starting to print the thing that it just finished printing. I'm seeing it happen when I add to queue from Slicer then press start on the printer's LCD.
Related: https://forum.prusa3d.com/forum/bugs-errors/connect-is-printing-queue-items-multiple-times/
Possibly related: https://forum.prusa3d.com/forum/bugs-errors/print-starts-when-i-hit-set-ready-even-though-i-never-put-anything-in-the-queue/
This post was modified před 7 months by Duck
Napsal : 13/07/2025 5:54 pm
Cornelius Grimm
(@cornelius-grimm)
I have the same issue, and it makes the print queue feature useless for me. :/
Napsal : 15/07/2025 7:41 pm
mnl_sch
(@mnl_sch)
When using Prusa Connect directly with an MK4S, completed print jobs remain in the print queue instead of being cleared automatically. This causes confusion and may lead to unintended reprints if the “Set Ready” button is pressed, since the previous job is still queued.
Steps to Reproduce
-Upload a print job to the printer via Prusa Connect.
-Start the print (“Print Now” or via queue).
-Wait until the print completes successfully.
-Check the printer queue in Prusa Connect.
Expected Behavior
Once a print finishes, the job should be marked as completed and removed from the active queue. Queue should be empty unless more jobs were manually added.
Actual Behavior
Finished job remains in the queue. If the printer is set to “Ready”, the same job may reprint automatically. Manual queue clearing is required after every print.
Impact
Risk of duplicate prints if users click “Set Ready” too quickly. Increased confusion for operators managing multiple jobs. Breaks expected queue workflow (automatic progression / cleanup).
Workarounds
- Manually clear queue after every job.
- Use “Print Now” instead of queuing jobs (avoids stuck entries).
System Info
- Printer: Original Prusa MK4S
- Firmware: 6.2.4+8909
- Connection: Prusa Connect via Prusa Slicer (direct, not via PrusaLink)
- Operating System: Windows 10
Napsal : 19/08/2025 4:24 pm
PiGood
(@pigood)
Was just going to post this issue but I see there is a thread.
Haven't been having this issue if I have a large number of items qued for printing on my CoreOne, but if I am sending something I am going to immediately print the issue will occur. Best I can tell, problem seems to occur due to setting the printer to ready and starting the print on the printer before the file transfer is complete, and once the file transfer completes it adds a copy to the que even though it has already moved the program from que to running.
Napsal : 07/09/2025 11:36 pm
PiGood
(@pigood)
I did a little more testing.
Send to connect -> Add to print queue, Add to 1. position in the queue. This is adding one to queue as expected, waited for file to fully transfer per connect. There is only one file in the que at this point and no active prints. Proceed to the physical printer and it shows the file, but has "Print" rather than "Set as Ready." Select "Print" on the printer and it will start printing. Connect will now show it as the active print, but still has the qued print.
So looks more like a communication bug between physical input on the printer and connect.
Napsal : 08/09/2025 11:02 pm
1 lidem se líbí
PiGood
(@pigood)
Bit more testing.
If you transfer the file to the printer as stated in my last post, but close the prompt on the printer, then go to Control -> Set As Ready it will properly pull from the que correctly.
So that points to it either being an issue with that print menu that appears on the printer when transferring the file or a or a communication issue.
As a side note, "Set as Ready" is in a terrible spot in terms of UI. As a commonly used feature there is no excuse for it being buried 2/3 of the way down the "Control" menu. It should really be under "Print" as the second drop down option after "Return" but before the list of files.
Napsal : 13/09/2025 11:59 am
Stránka 1 / 2
