Gcode Files from Printables are broken if you use the Print Button
Lorien
(@lorien)
Hello
i do have my mk4s connected to prusa connect. on Printables i select the Print Button for a gcode file. Then Prusa Connect opens up and shows this weird google stuff at the end of the gcode file, probably thats the reason why it is not working because it can't find a compatible printer.
Is there a solution for this or is this something new ?
coreboxx_project_secondary_mk4s_04n_02mm_petg_mk4s_10h16m_bed3.bgcode%3FX-Goog-Algorithm%3DGOOG4-RSA-SHA256%26X-Goog-Credential%3Dprintables-prod%2540prusa3d-printables-prod-a0b4.iam.gserviceaccount.com%252F20250625%252Fauto%252Fstorage%252Fgoog4_request%26X-Goog-Date%3D20250625T110708Z%26X-Goog-Expires%3D120%26X-Goog-SignedHeaders%3Dhost%26X-Goog-Signature%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
Opublikowany : 25/06/2025 11:11 am
