Gcode Files from Printables are broken if you use the Print Button
Hello
i do have my mk4s connected to prusa connect. on Printables i select the Print Button for a gcode file. Then Prusa Connect opens up and shows this weird google stuff at the end of the gcode file, probably thats the reason why it is not working because it can't find a compatible printer.
Is there a solution for this or is this something new ?
coreboxx_project_secondary_mk4s_04n_02mm_petg_mk4s_10h16m_bed3.bgcode%3FX-Goog-Algorithm%3DGOOG4-RSA-SHA256%26X-Goog-Credential%3Dprintables-prod%2540prusa3d-printables-prod-a0b4.iam.gserviceaccount.com%252F20250625%252Fauto%252Fstorage%252Fgoog4_request%26X-Goog-Date%3D20250625T110708Z%26X-Goog-Expires%3D120%26X-Goog-SignedHeaders%3Dhost%26X-Goog-Signature%3D97ada87ef5b248b5e3006d77c75bcc5bd4f1d0ff95e6f22a8f07a98117395092105085af9b514e725fed525b223cab8dbb19ca38eda25cea4d0f07c669bb0ca735fcc0ac8d9c979da9b7153b415ff8490a528b74587673f68d88ff5d3bd017fe53c657a8e85116ddabae364acb7321f436309b26400aa81cc3806615ac562bbca9b605c1725cb3be346b0107e489cb602c12737a78f98e56bb2bd06e0170af1447f21b409f44128c60ae8f3c5b286eb5d7017d6b6bf7780033801a5975c6812efa5b623a0946d8895522cab886a168b91e752a9b2a25d6f964385bd9afa73dda92f6bbd9e5dd7787f95f57d145b606dc8b6e827f671bee1838381c2ff418fc54
