Failed to start new print after crash detection
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4): rpi zero 2w
PrusaLink version: 0.6.0
Printer type: mk3s+
Printer UUID (you can find it in Printer detail page - address line): e0e8ce85-af37-4f49-894f-96ea2d0d4c8c
Printer firmware version: 3.10.1-4697
PrusaSlicer version (if applicable): 2.4.0
Description of the bug, including steps to reproduce (if possible):
A glob of filament caused a crash detection event. The printer stopped and showed the crash detection message on the display, asking if I wanted to resume printing. I said no, which aborted the print. When I tried to start a new print, prusalink thought there was still a print in progress and would not start the new print. I turned the printer off and on again to fix it.
Hi, the crash detection causes Link to go into an ATTENTION state, there's a bug in the 0.6.0 which breaks the serial line comms if the printer is left in an ATTENTION state for longer than a few seconds. There is a slightly newer hotfix version with this one issue fixed. https://drive.google.com/drive/folders/1aNw7KlKCaXgkNyXsDrIg0qzH8QUtRaB7?usp=sharing
There is a little less time consuming way to update, but it requires a little more skill with Linux (unpacking/mounting the img and connecting to the pi using sftp) - https://forum.prusa3d.com/forum/postid/580627/
Fortunately I work with linux (and even images/python) for a living so this is trivial for me 😛 I'll get this update installed and see if it makes the issue go away, thanks!
I just realized I actually have this version installed already.
RE: Failed to start new print after crash detection
Awesome, sorry for the trouble
