Error uploading to print host
ronguest
(@ronguest)
I have a MK4 running 4.7 and generally the connection from PrusaSlicer to Connect has worked perfectly. However today I got “error uploading to print host HTTP 500” for a modestly sized file. I tried a few times and kept getting the error. Then I exported the gcode from PrusaSlicer and uploaded it to Connect using drag-and-drop in my browser and that worked fine.
I then sliced a different model and PS was able to transfer it directly to Connect so I imagine there is something about the particular gcode.
Not a big deal but inconvenient.
Veröffentlicht : 19/07/2023 1:07 pm
Tojik
(@tojik)
Mitglied Moderator
RE: Error uploading to print host
Hi, what is the file if not under NDA. Could younsend it. Or we could try just the name, whether that prevents the upload by itself.
Veröffentlicht : 19/07/2023 1:23 pm
ronguest
(@ronguest)
The gcode file I uploaded via the browser printed fine. Afterwards I again tried to send the gcode from PS and it failed. I noticed the failure is when it is at 100% complete. I then slightly changed the name in the upload dialog and it completed ! Very strange to me. The name that fails is "tire_0.4n_0.2mm_PLA_MK4_59m.gcode" but when I changed it to "other-tire_0.4n_0.2mm_PLA_MK4_59m.gcode" it worked. BUT I cannot delete that file from the printer. The Delete button flashes red briefly and the file remains. So I need advice on how to delete it. I've attached the gcode file (a tire from Landy Mini model).
NEVER MIND about deleting the file. I walked over to the printer and that file was on the LCD screen asking if I wanted to print it. Once I dismissed that on the LCD I could delete the file.
Veröffentlicht : 19/07/2023 1:44 pm
