Confusing api versionig
I observed that API endpoint
/api/version
returns different values on different printers. For example PrusaLink for RaspberryPi returns 0.9.0-legacy
Even though it supports the new V1 endpoints.
XL at somepoint reported 0.1
https://github.com/home-assistant-libs/pyprusalink/pull/25#issue-1516593136
And MINI with non-V1 endpoints at somepoint reported >2.0.0
It is very confusing. Can someone clarify whan this value even means?
P.S. can somebody post response from /api/version endpoint including printer model and firmware version?
RE: Confusing api versionig
Prusa Mini+ with 4.4.1+4194 firmware on it (prettiefied json for readability):
"api": "2.0.0",
"server": "2.1.2",
"text": "PrusaLink MINI",
"hostname": "PrusaMINI"
One more thing, see https://github.com/prusa3d/Prusa-Link-Web/tree/master/spec and you should get better idea what is going on and what given printer is capable of.
Prusa Mini+ with that 4.4.1 firmware uses 'openapi-legacy' so the version can be high, but printers can use also other newer API (spec without legacy word).
Yes, I know about that. I thought, that printers with legacy API will use different api version number then V1 API. This is what I'm trying to figure out.
