Confusing api versionig
Cicicok
(@cicicok)
I observed that API endpoint
/api/version
returns different values on different printers. For example PrusaLink for RaspberryPi returns 0.9.0-legacy
https://github.com/prusa3d/Prusa-Link/blob/ee1a1c3fe4cb333d6d4f786f8b35d6ed769834da/prusa/link/web/main.py#L245
Even though it supports the new V1 endpoints.
XL at somepoint reported 0.1
https://github.com/home-assistant-libs/pyprusalink/pull/25#issue-1516593136
And MINI with non-V1 endpoints at somepoint reported >2.0.0
It is very confusing. Can someone clarify whan this value even means?
P.S. can somebody post response from /api/version endpoint including printer model and firmware version?
Veröffentlicht : 07/11/2023 8:23 am
_KaszpiR_
(@_kaszpir_)
RE: Confusing api versionig
Prusa Mini+ with 4.4.1+4194 firmware on it (prettiefied json for readability):
    "api": "2.0.0",
    "server": "2.1.2",
    "text": "PrusaLink MINI",
    "hostname": "PrusaMINI"
Veröffentlicht : 08/11/2023 7:28 am
_KaszpiR_
(@_kaszpir_)
One more thing, see https://github.com/prusa3d/Prusa-Link-Web/tree/master/spec and you should get better idea what is going on and what given printer is capable of.
Prusa Mini+ with that 4.4.1 firmware uses 'openapi-legacy' so the version can be high, but printers can use also other  newer API (spec without legacy word).
Veröffentlicht : 08/11/2023 7:37 am
Cicicok
(@cicicok)
Posted by: @_kaszpir_
Yes, I know about that. I thought, that printers with legacy API will use different api version number then V1 API. This is what I'm trying to figure out.
Veröffentlicht : 08/11/2023 7:43 am
