canot connect to printer
Hello
(@hello)
so i am trying to connect raspberry pi zero w via usb to my prusa mk3s+ but keep getting bellow
Veröffentlicht : 06/06/2023 5:08 am
Tojik
(@tojik)
Mitglied Moderator
RE: canot connect to printer
Hi, did you turn the RPi port off? It needs to be off for USB
Also, what version is the FW and PrusaLink
Newest Prusalink is the 0.7.0
Veröffentlicht : 06/06/2023 6:47 am
Hello
(@hello)
Yes rpi port off fw printer 3.11 latest stable prusalink version
Veröffentlicht : 06/06/2023 7:27 am
Tojik
(@tojik)
Mitglied Moderator
Oh right, you're holding off on the temperature model.
The announcements of new prusalink versions are quite inconsistant IMO, is it really the 0.7.0?
Not sure how the 3.11 does with 0.7.0, should probably be alright... I'll try and check it.
Veröffentlicht : 06/06/2023 7:49 am
Hello
(@hello)
Ok thanks it is the latest stable version from yesterday
Veröffentlicht : 06/06/2023 9:16 am
Hello
(@hello)
@tojik any update have you got it to work
Veröffentlicht : 07/06/2023 7:25 pm
Hello
(@hello)
i can confirm i now have it working
Veröffentlicht : 08/06/2023 12:35 am
Tojik
(@tojik)
Mitglied Moderator
Oh, sorry, what did ultimately fix it?
Veröffentlicht : 08/06/2023 8:06 am
Hello
(@hello)
I changed pin def to be USB not gpio pin so when it trys to connect to gpio it ends up connecting to usb I do hope this gets fixed later on
Veröffentlicht : 08/06/2023 8:53 am
Hello
(@hello)
Ps chat got was a massive help in doing that it vertully did it for me
Veröffentlicht : 08/06/2023 9:02 am
Tojik
(@tojik)
Mitglied Moderator
Sorry, what? What did you change? Raspberry pin definition from GPIO to USB pin. I do not understand that
Veröffentlicht : 08/06/2023 10:13 am
Hello
(@hello)
i gave Google. Bard the code and asked it to change it so it gave data out of USB not gpio pins and what ever it did it worked
Veröffentlicht : 08/06/2023 7:37 pm
Hello
(@hello)
The thing is now it won't connect via gpio pins but I don't want that anyway
Veröffentlicht : 08/06/2023 7:38 pm
Tojik
(@tojik)
Mitglied Moderator
You do you, it might be the 3.11 for all i know throwing off my attempt at automatic port select.
Veröffentlicht : 08/06/2023 7:44 pm
Hello
(@hello)
Yeah possibly in the next realese I'll try it again with 3.11 also do you have ssh command to flip camera view
Veröffentlicht : 08/06/2023 8:15 pm
Tojik
(@tojik)
Mitglied Moderator
Nope, those would go into camera settings. And I don't think trying anything with the 3.11 will do much good. PrusaLink might be getting some support in FW, so at some point, the newest FW will be required. Now it might just fail to report fan errors and stuff that got changed since 3.11. I'm really deving against the current version. It would get more tangled trying to support every version, and the testing would get impossible.
Veröffentlicht : 08/06/2023 8:22 pm
Hello
(@hello)
So say I went to 3.12 would it be possible then if so how many thanks
Veröffentlicht : 08/06/2023 8:30 pm
Tojik
(@tojik)
Mitglied Moderator
If it works now, use it that way. If you got a revo, the temp model might be annoying, so I don't blame you for sticking to 3.11
The potential break in compatibility is not coming for a long time
Veröffentlicht : 08/06/2023 8:35 pm
Hello
(@hello)
I don't have revo but will stick to 3.11 thanks for your help
Veröffentlicht : 08/06/2023 8:36 pm
