Buddy3D Camera: Timelapse setting resets after each reboot
samuel-t
(@samuel-t)
Hi
I added a Mini-SD card to my Buddy3D Camera and enabled the setting “Timelapse → Permanent timelapses on SD card”. However, this setting resets (switches off) after every Buddy3D Camera reboot.
Can anyone confirm this behavior?
Postato : 04/09/2025 7:36 pm
samuel-t
(@samuel-t)
RE: Buddy3D Camera: Timelapse setting resets after each reboot
Prusa just released a new version of Prusa Connect, and the camera settings are now also visible there - not only in the mobile Prusa app.
On the desktop version, a “Job name” is required. I believe Prusa intentionally disables the flag for each new print, whereas I would expect the setting to stay enabled once it has been turned on. It’s probably just a misunderstanding of how the feature is meant to work, since there isn’t much information about it.
In any case, I assume it works as intended, though it’s not very user-friendly. It’s also a bit of a pity that some settings and views are only available in the mobile app, while others (e.g. cancelling objects) are only available in the desktop version.
Postato : 05/09/2025 8:44 am
