Camera disconnecting from Unifi WIFI and refusing to reconnect
ZombieSapiens
(@zombiesapiens)
I have an IoT dedicated 2.4GHz SSID for all my IoT devices (>150). This SSID is setup to be as compatible as possible with all IoT devices, and other than a Sonos One, the Prusa Camera (the internal one) is the only device that struggles to stay connected. All the networking gear is UNIFI and I run the latest firmware. There are 5 APs, with one of them being within 3m of the Prusa Core One+ printer and camera.
The only way I have found to reconnect the camera is to connect my phone to the IoT SSID and show the camera a new QR code. This is getting annoying and I wonder what, if any, setting might be causing this issue... or whether this is a device issue (more likely since it is the only device having issues).
Posted : 24/03/2026 9:55 pm
Dan
 Dan
(@dan-25)
RE: Camera disconnecting from Unifi WIFI and refusing to reconnect
Sorry, no solution. I'm in the same situation. If anyone can get it working on a Unify network please let us know.
Updating to camera FW 3.1.4 at least made the camera report "connection successful" and reconnect after power cycle. I can see the camera connected in unify controller. Rx/Tx data is 0 though...
I've tried to make a dedicated 2.4Ghz network with the absolute simplest configuration possible... I'm also very frustrated at this point. This is by far the worst connectivity firmware in a device I've encountered. I have multiple espressif based devices on my network and even though they generally only support 2.4 Ghz I've never had to create a separate network for them before.
When creating a hotspot on my phone the camera connects and send a picture to the app so to me this indicates a crappy firmware rather than a hardware issue.
Posted : 09/05/2026 6:40 am
Dan
 Dan
(@dan-25)
Wow, just when I thought it was impossible I actually fond some settings that worked. I'm not sure which of them that enabled the connection.
Changes I made:
Created dedicated vlan.
Assigned my iot wifi to the new vlan.
Manually assigned 2.4ghz bands to accesspoints
Changed power from "auto" to "medium"
The base was the following instructions, I already had some of them configured:
1. Create a Dedicated IoT Network (VLAN)
Go to:
Settings → Networks → Add New Network
Configure:
Name: IoTVLAN ID: e.g. 30Gateway/Subnet: choose your preferred subnet
This separates IoT devices from your main network.
2. Create a Dedicated IoT WiFi SSID
Go to:
Settings → WiFi → Add New WiFi Network
Configure:
SSID Name: e.g. IoT-2.4GSecurity: WPA2-PSKNetwork: Select the IoT VLAN/network created aboveBands:Enable 2.4 GHz onlyDisable 5 GHz and 6 GHz
Many IoT devices do not support WPA3 or mixed WPA2/WPA3 modes.
3. Optimize IoT WiFi Settings
Under the IoT WiFi network → Advanced Settings
Recommended:
Disable Fast Roaming (802.11r)Disable BSS Transition (802.11v)Disable UAPSDDisable Multicast to UnicastDisable WPA3 / PMF transition mode if devices have issues
These settings improve compatibility with inexpensive IoT chipsets.
4. Optimize Access Point 2.4 GHz Radio Settings
Go to:
Devices → Select AP → Settings
Recommended:
Channel Width: HT20 (20 MHz)Transmit Power: Low or MediumUse non-overlapping channels:AP1 → Channel 1AP2 → Channel 6AP3 → Channel 11
Do NOT use overlapping channels on nearby APs.
Posted : 09/05/2026 9:06 am
