Z-Axis offset incorrect depending on the print?
pnewton
(@pnewton)
I'm trying to print the Herringbone Planetary Gear from here (specifically the user-contributed print for the Mini provided by Pax); whenever I start to print from this gcode, the first layer is so low that I barely get a smear of PLA. I barely know what's going on - if someone knows, will you please clue me in to what to do to fix the problem, as well as maybe the reason I'm encountering this so I can figure it out if I ever see it again?
This is my first printer, and I seemed to be able to complete the setup and "first layer calibration" successfully. I printed the prusa logo bar, as well as 3d Benchy, but neither of these gave me this problem with the first layer.
Opublikowany : 20/09/2021 4:59 am
JMH714
(@jmh714-2)
Do you have two separated sheets such as smooth sheet and textured sheet or something like that?
If you switched the sheet after first layer calibration - you will need to re-run a new calibration for different sheet. Because smooth sheet is thicker than texture sheet.
Opublikowany : 20/09/2021 2:20 pm
pnewton
(@pnewton)
Re: Z-Axis offset incorrect depending on the print?
Thanks for the help - in this case the sheet is the same. My last three troubleshooting steps have been :
  • Rerun first layer offset calibration - printed fine
  • Attempt to print benchy - worked fine
  • Attempted to print gear again - first layer starts out as a smear once again
Opublikowany : 20/09/2021 4:03 pm
JMH714
(@jmh714-2)
It's very likely the gcode is bad. Whenever I download any of people's designs - I've ran into some "bad" gcode. I always download non-gcode and I would run it on Slicer to create my own gcode and then print it.
Opublikowany : 20/09/2021 5:33 pm
