Z axis not moving
Sebastian
(@sebastian-5)
Z axis not moving
I just updated to the latest firmware and wanted to print on my mini. Now the Z axis is not moving anymore. Doesn't need to have to do anything with the upgrade though.
If I recall correctly, you should be able to manually move the axis, not just trough the software, but also by turning the thread physically? It seems completely stuck but since I didn't use it for a while I'm not sure anymore.
Publié : 19/12/2022 5:52 pm
René
(@rene-3)
RE: Z axis not moving
If you select settings in the printer menu,
and then select disable steppers,
is the Z axis still stuck?
Publié : 20/12/2022 2:26 pm
Sebastian
(@sebastian-5)
Stuck as in I should be able to move the thread with my hand? Then yes, it’s still stuck.
Publié : 20/12/2022 4:07 pm
René
(@rene-3)
Have you lubricated the z spindle?
If so, degrease the z spindle and nut!
Publié : 21/12/2022 6:05 am
@rene-4 has a good point.  The leadscrew and follower are self lubricating and should not be oiled.  The smooth rod next to it must be oiled.
Publié : 21/12/2022 11:01 am
Sebastian
(@sebastian-5)
The lead screw is not lubricated.
Sorry if I have been unclear about the situation., The mini isn't a new model and was working for quite some time. I ust didn't use it for a couple of month. Finished a print, turned it off, some month later turned it on and made the firmware upgrade. Started a print which failed homing and then discovered the Z-Axis seems to be completely stuck and not moving. The mini is located in a dry, well temperated room and enclosed that it didn't really even collect any dust during the month months not using it so I was very surprised when it seem to be stuck like that.
Publié : 21/12/2022 4:16 pm
René
(@rene-3)
OK. then it might be worth downgrading to the previous firmware., where your printer worked fine.
Publié : 21/12/2022 5:05 pm
Is this with power on and off?
Publié : 22/12/2022 2:35 pm
Sebastian
(@sebastian-5)
Yes. Power on or off makes no difference. Disabling steppers also not. I was just not sure anymore if it should be movable by hand since I didn't use it for some time and don't understand how it can get so stuck without using it.
Publié : 22/12/2022 3:17 pm
Steppers don't fail like that ...
Time to contact Prusa support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Publié : 22/12/2022 7:01 pm
1 personnes ont aimé
