Z axis behaviour and quality
Hi
i try to understand way i get this result. first i try to print the Betchy boat but i notes after 22 mm start the printer produce bad result. i printed three time same result i get. then i change the model to other model to find out what is the problem. but i cant find way. my opinion it is the rod of Z axis. i put some lubrication but no result. also i open the Z axis and close it again but i don t find clear problem. however could
be some different resistance in some are but it is difficult to me measure it.
any suggestion??
Best Answer by Ahmad:
ii found the solution and like to share it with you.
it is the part which holding the z axis. only i release the 2 nut and work ok now.
i think it was over tied.
RE: Z axis behaviour and quality
an amazing improvement for such a small change, good job!
