Z axis behaviour and quality
Ahmad
(@ahmad)
Hi
i try to understand way i get this result. first i try to print the Betchy boat but i notes after 22 mm start the printer produce bad result. i printed three time same result i get. then i change the model to other model to find out what is the problem. but i cant find way. my opinion  it is the rod of Z axis. i put some lubrication but no result. also i open the Z axis and close it again but i don t  find clear problem. however could be some different resistance in some are but it is difficult to me measure it.
any suggestion??
Best Answer by Ahmad:
ii found the solution and like to share it with you.
it is the part which holding the z axis. only i release the 2 nut  and work ok now.
i think it was over tied.
IMG_6114_2
Respondido : 17/12/2020 10:58 am
Ahmad
(@ahmad)
RE: Z axis behaviour and quality
IMG_6114_2
Respondido : 17/12/2020 12:27 pm
2 les gusta
remington
(@remington)
an amazing improvement for such a small change, good job!
Respondido : 17/12/2020 5:30 pm
