Y-Axis won't pass
Sievers05
(@sievers05)
Y-Axis won't pass
Hello again from Texas,
Over the last two days I've been trying to realign the y-axis on my mini +. I do not have a clue how that happened. I've watch a couple of you tube videos that use a precision square to make sure both sides of the print bed are square. I would very much appreciate all advice on readjusting the y-axis on my mini.
Thank you
Sievers05
Opublikowany : 31/07/2023 1:18 am
The assembly is spread through this page:
https://help.prusa3d.com/guide/2-yz-axis-assembly_196824
If the frame is square and the carraige is not binding then I would look closely at the Y carriage bearings; if it's binding then check the smooth rods.
Opublikowany : 31/07/2023 8:03 am
