Y belt not tensionned
Ordimans
(@ordimans)
Hello,
This morning, I just noticed after a printing failure, that the Y belt was no longer tight, and the part on the front unscrewed.
I screwed it back in, but the strap is not tight.
I had flexible filament that got caught in the strap, but I cleaned everything.
How do you make it tender again?
The test failed on the Y axis.
Ce sujet a été modifié il y a 6 years par Ordimans
Publié : 30/04/2020 9:34 am
3Dprintedgr
(@3dprintedgr)
RE: Y belt not tensionned
You have tightened the two screws in the front all the way and still your belt is loose?
If that's the case then you need to check the Y belt holder which is under the bed. It sounds quite strange but maybe something happened that made the belt come out of position.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Publié : 03/05/2020 5:29 pm
Ordimans
(@ordimans)
Hello
Thanks you, i set the holder, it's ok .
Publié : 03/05/2020 5:31 pm
1 personnes ont aimé
