X axis problem
Martin Dočekal
(@martin-docekal)
X axis problem
So I have this problem when I try to autohome on my prusa mini it moves the X axis but it goes to the side and it crashesh in to the plastic part. Any ideas how to fix this ??
Opublikowany : 01/10/2020 3:51 pm
RE: X axis problem
Posted by: @armanon
Hello and welcome to the Prusaforum!
Does the X-axis run easily and without obstacles from left to right? Have you oiled the linear bearings a little bit? Does the belt tension fit and  is the belt pulley well tightened?
Opublikowany : 01/10/2020 4:11 pm
Martin Dočekal
(@martin-docekal)
RE: X axis problem
@karl-herbert
Yeah it moves smoothly but it doesnt stop on the ends its trying to move. The bearing are oiled and the belt tension should be fine
Opublikowany : 01/10/2020 4:26 pm
Martin Dočekal
(@martin-docekal)
RE: X axis problem
Here is a video ( not mine printer but the guy has the same problem as me  )
Opublikowany : 02/10/2020 6:23 am
Martin Dočekal
(@martin-docekal)
RE: X axis problem
So I now know what was the problem. I removed the lid from the box with the electronics and it seems to have fixed my problem.
Opublikowany : 02/10/2020 6:12 pm
