RE: What causes horizontal banding?
Your layers seem to be really good just like your quality.
Can you feel these lines or is it on the inside? The first things I would try is to increase the perimeters and change the type of infill. Maybe the transparency of this specific filament is causing the problem. For example a black color would not have the same effect on your print.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Opublikowany : 25/03/2020 3:43 pm
Have you tried increasing the X and Y belt tension? This helped with the banding in my case.
Opublikowany : 29/03/2020 2:07 pm
