Weird groaning noise on Z axis
singlefin
(@singlefin)
Just got my shiny Mini+ (not kit) and found this peculiar groaning noise from Z axis moving down while running the self test.  Which part could be causing this?  Since I didn’t assemble the printer, I’m unsure where to check…
IMG_9001
Opublikowany : 05/10/2021 7:57 pm
singlefin
(@singlefin)
Please click on "IMG_9001" for the video...  Thanks
Opublikowany : 05/10/2021 8:53 pm
singlefin
(@singlefin)
Here's the video:
Opublikowany : 06/10/2021 9:33 pm
abacabie
(@abacabie)
Z axis
make sure that the trapezoidal nut under the X-axis assembly is not to tight, maybe loosen a bit then run the Z-axis up and down and hand tighten again, had the same issue.
Opublikowany : 07/10/2021 12:10 pm
singlefin
(@singlefin)
You are referring to the black collar/sleeve looking thing screwed (2 x M3 screws) to the bottom of the orange XZ motor drive assembly that travels up and down the Z axis?
Opublikowany : 07/10/2021 1:44 pm
abacabie
(@abacabie)
Yes
yes, that's the one, i had the same issue, its very easy to over tighten this.
Opublikowany : 07/10/2021 2:42 pm
Judas
(@judas)
Z
Abacabie is definitely correct, mine did the same thing and I had to loosen one of those two screws. One was very tight while the other was loose.
Opublikowany : 07/10/2021 8:30 pm
singlefin
(@singlefin)
Thanks for your help, I have loosened the two bolts and re-tightened lightly, no more groaning noise while performing Z-axis self test.
Opublikowany : 09/10/2021 9:29 pm
Daniel-san
(@daniel-san-2)
Worked for me as well
Thanks for the tip, my pre-assembled Mini+ also had this noise when moving down, and loosening/hand tightening the two nuts underneath has resolved it
Posted by: @abacabie
Opublikowany : 18/10/2021 8:19 pm
