warping , lifting prints
hi ,
like many on here a newby to this 3d world.
firstly , i did not get on with pla , using asa on smooth sheet with success.
Two problems i have found to be aware of so far , the filament idle screw adjustment is very important to flow of filament , so experiment with it , head of allen screw clearly above the plastic surface level seems best sofar.
Also watch out for the front fan shroud moving and hitting the print when the head moves !. the single screw mounting does not stop tilting downwards on the unsupported end.
CHECK THE CLEARANCE !.
I have also unticked the "retraction wipe" function in the advance settings in the prusa slicer settings , this seems also to help .
Napsal : 21/05/2020 10:42 am
1 lidem se líbí
