Training not aligned, normal?
Hello 🙂
I have just mounted the printer, I push the filament, and start the loading of the filamenent, I hear that the motor is running and the wheel is also above, but the filament is not taken by the gear, I I took it apart and saw that the alignment is not good, I checked the assembly steps and I don't think I forgot anything.
An idea of the problem ?
Opublikowany : 03/06/2021 11:38 am
RE: Training not aligned, normal?
Is the spring installed on the tensioner? Have you adjusted the tensioner?
Opublikowany : 20/06/2021 1:27 am
For me, that's outside of "acceptable" tolerances -filament path (hole) is almost half diameter off.
[Mini+] [MK3S+BEAR]
Opublikowany : 20/06/2021 8:31 am
