Top Layer not closed
Boas
 Boas
(@boas)
Hi
on some models the top layer doesnt get closed. It looks like the top player is not printed
The top and botfill pattern is Monotonic. I had an infill fo 20% the general fillpattern is Gyroid.
I tried layer heights from 0.1-0.2
I increased the minimum shell thikness to 1mm and set minimum solid layers to 7 for the top layer but it doesnt seem to change anything.
Here an image (sorry for the bad quality)
Any advice?
This topic was modified 5 years temu 2 times by Boas
Opublikowany : 11/04/2021 8:56 am
Clarmrrsn
(@clarmrrsn)
RE: Top Layer not closed
Its really difficult to see, maybe a further away picture in focus of your entire model would be better.
What's the first layer like?
Is the top layer using supports or just printed onto infill?
Top layer issues can originate at the first layer.
I would suggest using life adjust Z - my way – Assembly and first prints troubleshooting – Prusa3D Forum (prusaprinters.org) to nail the first layer, give the bed a good clean with unscented dish soap rinse with lots of hot water and dry quickly on a radiator or on the bed.
Tank you very much!
Opublikowany : 11/04/2021 10:19 am
Boas
 Boas
(@boas)
The First layer looks good.
I think top layer is just printed onto fill. didnt change anythign there 🙂
Here you can better see the toplayer
Bot Layer
Opublikowany : 11/04/2021 10:32 am
