The prettiest benchy I’ve seen... until
Robrob
(@robrob)
any idea on why I woke up to this?
Postato : 18/02/2020 2:58 pm
vintagepc
(@vintagepc)
Utenti
RE: The prettiest benchy I’ve seen... until
My money's on your part having come loose from the print bed near the end.
Proper cleaning and handling practices are a must:
http://projects.ttlexceeded.com/3dprinting_bed_adhesion.html
http://projects.ttlexceeded.com/3dprinting_bed_cleaning.html
(especially point 6 works wonders for many)
Postato : 18/02/2020 5:09 pm
Robrob
(@robrob)
Yes, both the bench and the skirt were loose and in different parts of the bed.
And subsequent test prints the first layers aren't sticking at all really, even though I am wiping down with IPA each time.
I will try Dawn before the next one.
Questo post è stato modificato 6 years fa da Robrob
Postato : 18/02/2020 5:54 pm
Lichtjaeger
(@lichtjaeger)
I think the chimney was overheated. Could be to fast (low layer time because smallest part of the object), to hot or to less cooling.
Postato : 18/02/2020 6:14 pm
Robrob
(@robrob)
@lichtjaeger
it is straight off the USB drive that shipped with the printer, wouldn't  it be sliced/setup with the mini in mind though?
Postato : 18/02/2020 6:45 pm
Lichtjaeger
(@lichtjaeger)
Then tell us more. Did it came loose? What filament did you use? Is the printer also in an "out of the box" state or did you do a modification (other nozzle for example)?
Postato : 18/02/2020 6:51 pm
Tomas T
(@tomas-t)
@robrob
I had what look like the same issue with one of my first Benchys.
For me it was the issue that my z-layer was to high and that it did not stick to the sheet. First picture is the on the failed, second it work really well
I actually lowered the Z a small bit more since then.
See my post on the topic here:
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/unofficial-prusa-mini-wait-thread/paged/114/#post-194410
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/unofficial-prusa-mini-wait-thread/paged/115/#post-194505
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/unofficial-prusa-mini-wait-thread/paged/115/#post-194530
Hope it helps
Postato : 23/02/2020 10:19 am
