Temperature Tower
herbert
(@herbert)
Temperature Tower
I was searching for a temp tower working with the Prusa Mini. I even downloaded some and started to do some range modifications with PrusaSlicer. Figured out, that temperature is nothing you can modify with PrusaSlicers Range Modifiers.
I read about GCode modifications and others, but as I am new to the 3D Printing World, this is something I save for later.
Does someone has a working "way", file (3mf, gcode) etc for testing PLA, ASA and PETG on the Mini properly. Got some new spools of filament and also got told this should be the first thing to print, to figure out which temperature is fine for the filament.
Thanks
Napsal : 25/05/2020 6:12 am
Oxygen
(@oxygen)
RE: Temperature Tower
I did not do this myself : this guy has a complete set of instructions:
https://sites.google.com/view/newbieprusaminireview/home
Stock MK4S with FW 6.2.6
Napsal : 25/05/2020 7:24 am
herbert
(@herbert)
@oxygen
Thanks, I wonder why nobody can just offer the file to download 😀 as gcode or even as a 3mf. - I dig through this as soon as I do have some time to concentrate.
Napsal : 25/05/2020 9:11 am
mark
 mark
(@mark)
@herbert
"This Guy" here. I didn't upload a G code file because there are so many other options to set first in the slicer, filament choice, layer height and any changes you want to make to retraction, speed, etc. I'm not allowed to upload the stl file in this forum. Set up the slicer to your liking, load up the stl file and paste the custom gcode in the Printer Settings tab, Custom-G-Code section, Before layer change G code entry. Then slice and you have what you need to print.
Regards,
Mark
Napsal : 25/05/2020 12:00 pm
1 lidem se líbí
mark
 mark
(@mark)
I added sample files to my site.
Regards,
Mark
Napsal : 25/05/2020 12:11 pm
Oxygen
(@oxygen)
Sorry Mark, I made you "This Guy" 🙂 Your guide is really helpful.
Napsal : 25/05/2020 12:31 pm
herbert
(@herbert)
Posted by: @marklgoldberg
Regards,
Mark
This helped me a lot 🙂
Thanks
Napsal : 29/05/2020 10:03 am
steve
(@steve-13)
@marklgoldberg
That is awesome and thanks for sharing - I never thought about a smoke detector but I really, really like the idea of that.
Steve
Napsal : 30/05/2020 3:19 pm
