Step 25 of Mini assembly: No hole for y-axis thermistor cable
magro
(@magro)
Hi all,
I just bought a Prusa Mini and am stuck at step 25 of the assembly. I hope you can help: The online manual clearly shows a hole on the right side of the electronics box for the y-axis thermistor cable. It says that I should put the thermistor cable through that hole into the electronics box. As you can see on the picture the electronics box doesn’t have that hole in my case. I couldn’t find a hint in the online manual or here in the forum. Probably I am missing something, hope you can help. Thank you!
Best regards
Markus
Best Answer by davidmmx:
So, sorry for the noise. I checked online
https://help.prusa3d.com/ja/guide/mini-test_177717
There's another hole we can use for that. It would be better to update the manual to avoid the confusion, but I'm still sorry for not having checked online before.
Check step 2
Publié : 27/03/2021 12:51 pm
1 personnes ont aimé
davidmmx
(@davidmmx)
RE: Step 25 of Mini assembly: No hole for y-axis thermistor cable
Same here. I was aseembling it today, received it a week ago. No marks on the case suggesting that there was an attempt of doing the hole.
I hope we don't have to buy additional tools to make a hole, but I think it's going to be the solution.
Publié : 27/03/2021 1:24 pm
davidmmx
(@davidmmx)
Check step 2
Ce message a été modifié il y a 5 years par davidmmx
Publié : 27/03/2021 1:39 pm
magro
(@magro)
@davidmmx
Thanks! I must admit that I did not find your link either. Another proof that usually (me as) the user is the problem 😉 I used the other one with a previous version.
I spotted the hole and didn't get the cable through right away. Then I'll try again.
Ce message a été modifié il y a 5 years 2 fois par magro
Publié : 27/03/2021 2:33 pm
