Prusa Mini - Gaps in Layers
Hello there!
So I’ve had 3 Prusa mini’s for about 3 years now and have noticed as of late these random gaps in my layers. This is happening across all 3 machines.
My z is calibrated perfectly as I can print a 0.2mm thick sheet of PLA the same size as the bed and there are no gaps between the lines.
I have checked my belt tension, and screw that adjusts the grip on the filament. I also have hardened steel plated brass nozzles.
I am stuck as to what the problem might be? Are the printers just showing signs of general wear and tear? Is there something else I can do. I appreciate any help. I have attached a picture below.
(I am using the same print and filament settings I have used for the past 3 years with no issues)
RE: Prusa Mini - Gaps in Layers
do they all report error in the same place?
also check ptfe tubes and the bowden tube between the exturder and the hotend
