Problema with first layer calibration
Hi, I have to calibrate the first layer and the auto-loading does not go even though I first heat the printer and even if I insert the filament with the load filament command once finished and implement the first layer, I get the message to insert the filament, I have tried several times and although the filament is inserted it tells me to insert, what should I do? Thanks in advance
Opublikowany : 17/08/2020 7:13 pm
RE: Problema with first layer calibration
Do you have a filament sensor? If not, disable it in the settings. If you do, perhaps it has a loose connection or some other flaw.
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Opublikowany : 18/08/2020 8:56 am
