Prints are not in contact with the print bed
Harry6217
(@harry6217)
The bases of the printed items are not completely attached to the print bed.
MagSensorBody-70462001 5-PiecesNew
Postato : 31/01/2024 4:40 pm
mark
 mark
(@mark)
RE: Prints are not in contact with the print bed
Posted by: @harry6217
What type of filament are you using?
Check the first layer calibration.
If you are using ASA or ABS, try an enclosure and a full height draft shield. Print Settings | Skirt and Brim | Skirt | Draft Shield.
That will result in less warping and pulling off the bed.
Regards,
Mark
Postato : 31/01/2024 5:39 pm
Harry6217
(@harry6217)
Filament is Hatchbox ABS (I do have Prusament ABS also). This may be a stupid question but when you are talking about an enclosure could it be something so simple as a large cardboard box?
Postato : 31/01/2024 5:58 pm
Just google for 3D print warping and you'll see thousands of comments and suggestions. My standard copy-and-paste:
It's common for large box-shaped/rectangular objects to warp. Assuming Live Z is well calibrated and the steel sheet is clean (using hot water and fragrant-free dish washing soap), here are a few approaches that have worked for me (copied/pasted from previous posts):
  • Slow down print speed.
  • Add Mickey Mouse ears to the corners. There's a "helper disk" in PrusaSlicer's Add Part library but I prefer to simply add a cylindrical, maybe 10mm diameter, change height to single layer height, then place the part at the corner. Repeat for each corner.
  • Add a brim around the model, 5 mm or more. Wider or 2 -layer high brims may be needed but may not work with the size of the model or may require being added in your CAD software.
  • Use Layerneer Bed Weld ( https://www.amazon.com/Printer-Adhesive-Layerneer-Original-Filament/dp/B079984GV5/ ), Magigoo, etc. You only need a thin layer.
  • If you have design control over your part and it's possible considering the intended use, you can try to round the edges and/or add holes to the base of the model.
  • Combination of above.
  • Usually, brim/ears does the job, or some Layerneer if needed, but large, rectangular objects can be a challenge. Also, drafts can encourage warping, so printing in an enclosure (with doors open for PLA) may help.
Postato : 31/01/2024 6:38 pm
1 persone hanno apprezzato
A large cardboard box would do!
Joan
Postato : 31/01/2024 7:13 pm
Harry6217
(@harry6217)
Thank you for the suggestions. Will try on the next run.
Postato : 31/01/2024 7:20 pm
mark
 mark
(@mark)
The only issue with a cardboard box is if the print comes completely off the bed and you get a spaghetti monster (google that) you won't see it. An Ikea Lack table and 4 pieces of plexiglass works great. There are threads on enclosures.
ABS is particularly sensitive to warping and an enclosure is a major help.  I fear that if you continue without one you will continue to have problems. ABS is also very smelly and the fumes are bad for you. I hope this is in a ventilated location.
Regards,
Mark
Questo post è stato modificato 2 years fa da mark
Postato : 31/01/2024 9:02 pm
Brian
(@brian-12)
A lack enclosure would be ideal, but to solve your not seeing it issue just cut a hole in the box to view thru and just reattach the piece as a flap with some tape.  Then you can keep an eye on it.
Good luck.
Postato : 31/01/2024 9:12 pm
Do yourself a favor and use ASA instead of ABS. Same properties but UV resistant, smells less, and prints much more nicely.
Postato : 31/01/2024 9:44 pm
mark
 mark
(@mark)
Posted by: @fuchsr
+1 to that. My ASA prints come out pretty well using stuff on the list from @fuchsr, skirt and brim, and the enclosure.
On the box enclosure, just cut a hole and tape a piece of plastic wrap over it to see what is happening.
Regards,
Mark
Postato : 31/01/2024 9:48 pm
