[Solved] Printing PLA only works at 260?
Steven
(@steven-2)
Hello,
We have 3 mini printers (brand new) 2 work good and the 3th has problems.... When printing PLA at normal temps, after a while the extruder can't puche the filament trough... When I raise the temperature to 260° C it can print...
I think there's someting wrong with the temp setting? Can I recalibrate (the hysteresis) it like on the MK2.5 and MK3?
Greetings
Best Answer by 3Dprintedgr:
Seems like you have the known problem with the clicking sound. It must be because you have a clog in you hotend. You need to replace your PTFE tube inside your hotend. The tube that you have at the moment is shorter which causes a gap where filament builds up. This probably melts because you raise the temperature but its still not correct. Check the link below. It has instructions about how to fix this issue.
https://help.prusa3d.com/en/article/clicking-extruder-under-extrusion-and-clogging-mini_112011
Let us know if it works.
Napsal : 29/04/2020 1:23 pm
RE: Printing PLA only works at 260?
Good afternoon Steven,
does the printer show the same temperature for both the Extruder and the Heatbed when first switched on?
Napsal : 29/04/2020 2:53 pm
3Dprintedgr
(@3dprintedgr)
3 things can be the root cause behind your fault. Faulty heating element, faulty sensor on your hotend or clogged nozzle which clears when raising the temperature. I would also suggest you start from the sensor as its the one causing problems for others too.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Napsal : 29/04/2020 3:36 pm
Steven
(@steven-2)
@Joan: the reading at startup ar the same (nozzel 17° and heatbed 18°)
@Geoper2: Heat elemet works I think... Sensor? How would I check it? Room temp reads consistent with the other printers. I have to check for a clogged nozzel, never did that before...
Just for helping diagnose the problem. I filmed whats happening... Printer started normaal and after a couple of layers it wouldn't extrude anymore. When I rase the temperature is goes again. I checked the nozzel sensor and it gives a reading of 142.2 kOhm at room temp.
Any thoughts?
Greetings
Steven
Napsal : 29/04/2020 8:29 pm
Hi Steven,
Could you try re slicing the model but reducing the Extrusion multiplier to say 90%
see if this stops the clicking from starting in the first place
Napsal : 29/04/2020 8:38 pm
oopsitsaflame
(@oopsitsaflame)
I had the same problem.
Exchanging the PTFE inside the hotend did fix it.
like here at 9:50:
This post was modified před 6 years by oopsitsaflame
Napsal : 29/04/2020 8:58 pm
3Dprintedgr
(@3dprintedgr)
This post was modified před 6 years by 3Dprintedgr
Prusa Slicer 2.6.0
Napsal : 29/04/2020 11:25 pm
1 lidem se líbí
Steven
(@steven-2)
Hello everybody,
It is definitly a cloged hotend...
need to do som fixing...
Thanks to everybody...
Steven
Napsal : 30/04/2020 9:32 am
bobc
 bobc
(@bobc)
Smoking gun right there....
Napsal : 30/04/2020 11:29 am
