Pattern in layers please help
mmmike
(@mmmike)
So I purchased a mostly assembled Mini+ a few weeks ago and have been having some issues with it.  Most of the prints come out with a "wave" pattern for lack of better description (image below).  Could this be caused by the slicer, or is this a mechanical issue?
Best Answer by bobstro:
Do you get the same patterns with the Prusa gcode samples? If so, you know it's not a settings issue. Likely hardware. I'd just log in to the online shop and contact support. You paid extra for it, so you should definitely use it!
Postato : 23/07/2021 8:19 pm
mmmike
(@mmmike)
Another example
Here is another example of a print where the "wave" pattern is visible, but to a lesser degree.  You can feel the bumps when running a finger over the print.
Postato : 23/07/2021 9:09 pm
Contact support
Postato : 23/07/2021 11:44 pm
mmmike
(@mmmike)
Thank you
Thanks for the reply and suggestion - I will test one of the gcode samples today and contact support if it is still an issue.
Postato : 24/07/2021 3:50 pm
