Opinions on my first print please?
Threepoint2
(@threepoint2)
Hi everyone, I’m new to 3D printers and this is my first ever print. I’d value your opinion on it and how it can be improved. This was printed on a mini in PETG (prusament) with the “quality” profile. Do I need to adjust the layer height? Any other comments or suggestions on this make? Thank you all in advance.
Opublikowany : 03/06/2021 3:15 pm
RE: Opinions on my first print please?
That is a pretty successful print.  Some parts look like the Z might be off.
Opublikowany : 03/06/2021 3:57 pm
Threepoint2
(@threepoint2)
@cwbullet
Thanks. It was a single printed piece. Do you think the Z axis need tweaking closer or further from the print bed; or is there another tweak I should consider. Ultimately, I am happy with the print but I am keen to learn via optimisation and continual refinement.
Opublikowany : 03/06/2021 4:29 pm
Pretty good for a first print.  Your first layer Z could go down a little - a fraction more squish.
Don't obsess on the detail at this stage.  For the first month the printer will be settling down and values will drift a little as it beds in.  In a few weeks you will need to do a full maintenance check, clean and lubricate then you can work on getting the settings just right knowing they will stay good for a long time on your now stable machine.
For now, make some useful basic prints, some basic errors (everyone does), establish a routine and generally get used to the process.
Opublikowany : 03/06/2021 6:25 pm
Threepoint2
(@threepoint2)
@diem
I've become adicted to this very quickly and I've a list of prints prepared. I'll tweak the first layer a smidge and just run with it as suggested. Good to know it's not a mile off the mark before contining. Thank's for the advice.
Opublikowany : 03/06/2021 7:32 pm
