Newly built mini failing self test on z axis
mrjayd
(@mrjayd)
So just finished putting together my new preassembled mini+ and it is failing on the z axis test. Goes to the bottom and then goes up about half way and stops and fails the test. Checked the wiring and all seems good and connected. Unplugged the connector from the motherboard and reconnected but still fails. Any suggestions?
Opublikowany : 27/03/2022 1:06 am
Chris Laudermilk
(@chris-laudermilk)
RE: Newly built mini failing self test on z axis
Makes sure the trapezoidal nut on the leadscrew is attached to the X-axis mount *just* enough to keep it from rattling.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 28/03/2022 2:24 pm
