More stringing then on my previous printer
Hawwwran
(@hawwwran)
Hi, what retraction value do you use? I found that 2mm is reasonable maximum on prusa web, but default from PrusaSlicer is 3.2mm. what value do you use? Do you have stringing issues? How to improve it?
I have come here to chew bubblegum and perfect my MINI ... and I'm all out of bubblegum.
Postato : 15/06/2020 7:32 am
Crawlerin
(@crawlerin)
RE: More stringing then on my previous printer
I left it at default and don't have much stringing even with PETG if filament is dry enough. Isn't the 2 mm value for MK3 printer? That one is direct drive (extruder feeds directly into hotend) while MINI is Bowden (long tube connecting extruder and hotend). Bowden systems have higher retraction values.
Postato : 15/06/2020 8:21 pm
