Little holes with new extruder?
Kenobi-XII
(@kenobi-xii)
Hello,
since I've changed my extruder to an Bondtech, now i have little holes in my print. Can someone Tell me what this could be??? Bondtech said i have to set the steps to 415 for the extruder. Could this be to low?
Thanks
Napsal : 19/08/2020 3:12 am
Oxygen
(@oxygen)
RE: Little holes with new extruder?
could it be that they are seam points?
Stock MK4S with FW 6.2.6
Napsal : 20/08/2020 9:07 am
Kenobi-XII
(@kenobi-xii)
No it was the Z-length retraction. The lenght was at 3.2mm and i changed it to 2mm. Now the holes are gone!!!
Napsal : 20/08/2020 9:16 am
Oxygen
(@oxygen)
Good tip, thank you
Napsal : 20/08/2020 10:03 am
Oxygen
(@oxygen)
basically you changed it back to defaults (screenshot is made to show the defaults)
Napsal : 20/08/2020 10:11 am
Kenobi-XII
(@kenobi-xii)
I know but for the Mini it is 3.2 I don't know why.
Napsal : 20/08/2020 10:41 am
Lichtjaeger
(@lichtjaeger)
Posted by: @thejokerse
Because the Mini has a bowden extruder. Not a direct extruder like the one the i3 MK3 uses. Those extruders usually need more retraction to compensate for the clearance within the PTFE-tube.
Napsal : 20/08/2020 10:46 am
Kenobi-XII
(@kenobi-xii)
Okay but a friend of me has a bondtech, too and He didn't need to change the lenght! How can this be?
Napsal : 20/08/2020 10:48 am
Oxygen
(@oxygen)
Strange, the screenshot I posted is from a stock PRSlicer with only a Mini profile...
Kenobi-XII
(@kenobi-xii)
Look at the lock, its opened. So it isn't stock.
Napsal : 20/08/2020 10:54 am
Oxygen
(@oxygen)
That is what I did when I opened the lock it showed me the value of 2
Napsal : 20/08/2020 11:00 am
Kenobi-XII
(@kenobi-xii)
I don't know man, I can only tell you what I was doing. Why its now 3.2 or 2 i don't know.
Napsal : 20/08/2020 11:22 am
Oxygen
(@oxygen)
It is strange indeed, I have located the INI profile and loo what I found
retract_length = 3.2
thus this is the value the printer really uses (when the lock is enabled)
Napsal : 20/08/2020 11:32 am
Kenobi-XII
(@kenobi-xii)
There you go, hehe
Napsal : 20/08/2020 11:45 am
