left side of X axis drooping?
darorio
(@darorio)
I've had the mini plus for a week and everything I've printed in the middle came out great.  When I tried using the whole bed the left side appears to be closer to the nozzle than the right.  I've gone through the whole bed leveling test prior to doing a print out but still having this issue.  Any other way to fix this problem?
Respondido : 17/09/2021 5:13 pm
Judas
(@judas)
Skew
When you tighten the 3 screws to secure the Z axis to the Y axis, if you overtighten the screws it can cause the printer to not be square anymore. You can try loosening the 3 screws and retightening them in the correct order and not too tight. If that doesnt help then this article explains how to fix the X axis being too low or too high https://help.prusa3d.com/en/article/xz-axis-skew-correction-mini_158518
Respondido : 18/09/2021 5:35 am
