[Risolto] left side bad print
geert
(@geert)
left side bad print
hello,
got a  prusa mini and started printing
every print on the right side is ok but wen it starts to print on the left side of the printerbed it goes wrong
every time at the same place
does  this sound familiar ?
idea's
gr geert
Postato : 10/04/2021 2:05 pm
Turro75
(@turro75)
RE: left side bad print
https://help.prusa3d.com/en/article/xz-axis-skew-correction-mini_158518
Postato : 10/04/2021 2:44 pm
geert
(@geert)
thanks, will try this as soon as possible
Gr geert
Postato : 10/04/2021 3:29 pm
@geert
But first give the print bed a thorough clean in case it's just a patch of fingerprints ruining adhesion at that point.
Postato : 10/04/2021 7:12 pm
geert
(@geert)
hey,
it is not only the first layer
it is the complete print up till the end
would like to show  a picture, but  can not get it on this forum
gr geert
Postato : 10/04/2021 7:28 pm
Posted by: @geert
Use 'Add Media' at top of form.
Postato : 11/04/2021 7:31 am
geert
(@geert)
thanks
Postato : 11/04/2021 12:12 pm
@geert
Do you mean every time you print this part? or every print you make?
What happens if you rotate the print, or move it to a different part of the bed?
Postato : 11/04/2021 4:18 pm
geert
(@geert)
hey hey ,
it was every print i made and yes it is solved
thanks torro75, it took only a few minutes
greets and thanks all
geert
Postato : 12/04/2021 10:20 am
