[Solved] LCD Assembly, what am I missing here
waqas
(@waqas)
Hi All,
I just received my Prusa Mini+, trying to assemble, following the directions... things were going fine until I got to the LCD assembly part. Something seems odd here, the LCD does not seem to fit/attach with the body properly, the M20 screw does not go all the way in either and reaches its limit way before its fully in. I tried to have a look at the online manual, the pictures show a slightly different part (could be an older version in the online pictures, but that does look like a proper fit for the LCD). This one now, just doesn't look right to me. Can someone please tell me if I am missing something or is this supposed to be like this? Thanks.
What I have: https://photos.app.goo.gl/u3VzyKLCigAiZ29k9
What assembly pictures show online (and looks like correct fitting to me):
(Please ignore the arrow with Allan Key, I am taking about the bottom left corner, where the LCD attaches).
Best Answer by waqas:
Okay, after some thinking, I gave it a second go. Turns out I was being too nice, and it needed some hard screwing :/ Almost felt like I was about to break the supplied Allan Key, but in the end, it does seem to work now. All good.
This topic was modified před 5 years by waqas
Napsal : 05/02/2021 1:58 am
waqas
(@waqas)
RE: LCD Assembly, what am I missing here
Napsal : 05/02/2021 4:50 am
Canardiain
(@canardiain)
I just got to this step and had the same issue.  There seems to be a problem with the manual and the actual part.  The manual (1.06) says to use M3x12 but this is not included, it's M3x20.  The manual shows a printed part but it's actually injection moulded. The M3x12 screw seems far too short and doesn't self tap into the injection moulded part... I also had to use the M3x20 and really screw down very hard.
Napsal : 16/03/2021 12:01 am
Lung
 Lung
(@lung)
Yes, the manual with mine has the same issue too as there are 2 variations of the Mini. The online manual mentions both but the paper manual doesn't. The only other difference that I could see was the hole for the Y axis cable. It's a bit annoying as I spent ages trying to get the spare M12 to grab the frame and it wouldn't.
Napsal : 16/03/2021 12:25 am
Canardiain
(@canardiain)
I just ran into the Y axis cable issue too.  I had to disassemble the whole thing to get the cable through the front hole.  The ribon cable for the LCD also doesn't line up with the cut-out... it's off by about 1/3.
Napsal : 16/03/2021 12:39 am
