Inconsistent Extrusion on First Layer - Sierpinski Pyramid
[Gelöst] Inconsistent Extrusion on First Layer - Sierpinski Pyramid
Ben McIntosh
(@ben-mcintosh)
Hello, I have a pre-built Mini+ and have been printing with fairly good results.  Today I'm attempting a Sierpinski Pyramid print and what's interesting is that on the first layer there are areas of over extrusion.  Is this likely a bed leveling issue or something else that I may be able to look into?  Hoping to dial this in to be more consistent across the bed.
Best Answer by Bob:
How are the remaining layers?  The primary function of a first layer is to insure proper adhesion to the bed and to prepare the print for the second layer.  There is a lot of theorizing about what the first layer does, but it makes sense to me that you'll use more material where there are dips in the bed surface and less material where there are rises in the bed surface to insure that the top of the first layer is completely flat.
Cheers
-Bob
Veröffentlicht : 17/01/2022 6:15 pm
Bob
 Bob
(@bob-2)
RE: Inconsistent Extrusion on First Layer - Sierpinski Pyramid
Cheers
-Bob
Veröffentlicht : 17/01/2022 11:54 pm
Ben McIntosh
(@ben-mcintosh)
The rest of the model printed beautifully so I won't worry about it.  I guess this is the first time I ever printed a model with details in the first layer but that makes sense that even after bed leveling there would be small surface irregularities.  Thanks!
Veröffentlicht : 18/01/2022 4:14 pm
