[Rozwiązany] How to remove the buddy board?
TeachThePrints
(@teachtheprints)
Are there any instructions on how to remove the buddy board? I have to remove all the wires coming from the hotend, but I'm stuck with the power switch as it's in the way of lifting the buddy board enough to be able to take out the hotend heater wires.
I was trying to replace the minda with a SuperPINDA, however, the Minda wires are entangled with the hotend heater wires in such a way, that it's not possible to just remove the MINDA. Hence everything needs to be removed, before the SuperPINDA can be installed.
Prusa Mini FW6.2.4
Opublikowany : 01/12/2020 4:27 pm
TeachThePrints
(@teachtheprints)
RE: How to remove the buddy board?
Missed the edit time, hence a new post
Below is a picture, why the disassembly is required. Two of the MINDA wires (brown and black) go under the other wires, while the third blue one wraps around...
I'm thinking cutting and resoldering might be quicker than disassembly 😀 but still looking for a non-destructive way of removing this probe.
Minda_wire_entangled
Prusa Mini FW6.2.4
Opublikowany : 01/12/2020 4:51 pm
@teachtheprints
You don't have to remove the buddy board for this. Just unplug the affected connectors and untangle the cables. The MINDA is relatively easy to remove. To do this you must remove the cable ties on the textile hose and then pull out the sensor cable. The sensor itself is only clamped with one screw.
Opublikowany : 01/12/2020 5:58 pm
TeachThePrints
(@teachtheprints)
^ That was me not realizing, that the hotend heater wires have a pull-connector. I saw the screws on the side, which hold the wires in that plug. So I was under the impression, I somehow have to unscrew those wires, which is problematic, as the screws are only accessible from the side, so not enough room inside the buddy enclosure plus the power switch wires are blocking access too.
One pull and the wires got out, such an easy fix.
SuperPINDA is now live 😎
Prusa Mini FW6.2.4
Opublikowany : 01/12/2020 10:05 pm
