Hot End Clogging Up
Technojunkie
(@technojunkie)
Hot End Clogging Up
Hello, I emailed my problem to PRUSA a couple of days ago but have yet to receive a response and so hope that someone in the community could please offer some advice. I assembled the MINI+ But have so far been unable to use it. The main problem is that the hot-end keeps getting clogged up and only a small amount of filament gets through, and most of the time none at all gets through. I’ve tried all the troubleshooting methods I could find, such as unscrewing the brass nuts either end of the filament tube, cold pulling, heating beyond the melting point, and cleaning out the nozzle. But, every time I do these routines it clogs back up again straight away. I’m 99% sure it’s the hot-end that’s the problem, since I tested the extruder in isolation and it worked perfectly fine. Any helpful advice would be much appreciated, thank you.
Respondido : 20/01/2021 11:29 am
avh
 avh
(@avh)
RE: Hot End Clogging Up
Your best bet will probably be to replace the PTFE tube in the hotend with the spare tube included with the printer per these instructions.
Respondido : 20/01/2021 11:43 am
Technojunkie me gusta
Technojunkie
(@technojunkie)
@avh
Thank you very much for the prompt response avh, I’ll give it a try later and let you know how i get on.
Respondido : 20/01/2021 11:49 am
Miembro
