heat bed temp sensor gone bad?
dchoe81
(@dchoe81)
I turned on the printer today and the heat bed is showing -15 degrees and blinking red. I unplug/re-plugged it back into the buddy board and downgraded to 4.01 and back to 4.03. Any time I try to do anything, I get a watchdog reboot. Any advice?
Thanks
Opublikowany : 25/02/2020 2:20 am
Crawlerin
(@crawlerin)
RE: heat bed temp sensor gone bad?
It is possible that sensor is bad, or wires broke. Not uncommon with MINI. https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pictures-say-more-than-a-thousand-words/
Chat with support to arrange replacement.
Opublikowany : 25/02/2020 2:48 am
valerietripathy
(@valerietripathy)
I've checked the wiring, tried using a different thermistor port and making sure the connector was properly plugged in, but to no avail. The fluctuations are brief enough that they don't cause any problems when printing.
Opublikowany : 25/02/2020 10:06 am
Texy
 Texy
(@texy)
Posted by: @valerietripathy
Are you replying to the correct thread ?
Opublikowany : 25/02/2020 11:51 am
