First print hickup
Hi there,
just received my prusa mini today. Setup worked without any problems.
But on the first print the grub screw for the thermistor fell out...
Didn't have a problem putting it back in.
Just letting you know, so it won't happen to next customer 😉
Cheers
RE: First print hickup
Hi there,
Cheers
Hello and welcome to the Prusaforum!
Thanks for the info!
This happens relatively rarely, but it does happen. Normally it is rather the other way round and the screws do not loosen if a thermistor change is necessary. Therefore I would use some ceramic or copper paste.
