First print, does this look right?
kebullen
(@kebullen)
New to Prusa and 3d printing in general. Below is the top layer (or the layer on the heat bed).
Is this normal? Should it be smoother? I assume this is a result of the first layer calibration. Just checking to see if it should be dialed in a little better. Using a new roll of Prusament PLA.
Best Answer by Hello:
Yeah the first layer cal needs to be adjusted a bit more it should be real smooth
Opublikowany : 08/03/2023 6:05 pm
Hello
(@hello)
Opublikowany : 08/03/2023 6:21 pm
1 ludzie polubili
NickAtNight
(@nickatnight)
RE: First print, does this look right?
Looks a little wonky.  Do you have a comparison to what someone else has made?
Opublikowany : 08/03/2023 6:22 pm
kebullen
(@kebullen)
Thanks, appreciate the feedback.
Opublikowany : 08/03/2023 6:38 pm
