First layer (extrusion?) issues, HELP!
Hello! I’ve had my Prusa Mini for a while now and it’s created some almost prefect prints, it’s a great little printer!
Recently my first layers have had gaps, blobs or generally inconsistent results, which seems to mostly occur around the start and end of extrusion.
I’ve been running a few print tests with different models, most of which I’ve printed many times before without issue, using the default Prusa settings, and Prusa filament.. I just can’t seem to solve this problem.
See images below:
Any thoughts would be very welcome?
many thanks, Ollie
Respondido : 24/09/2022 3:44 pm
RE: First layer (extrusion?) issues, HELP!
- Check your print temperatures. You might be printing too cool for the filament.
- If not, you might have a partial jam or block. Try a cold pull.
Respondido : 28/09/2022 10:33 am
