First assembly: Filament Sensor high-resistance
aegixx
(@aegixx)
When putting together the filament sensor, there is a high-resistance when pushing filament through the tubing.  Based on the instructions, it sounded like there should be little to no resistance.  Can I get some feedback on this?
Publié : 16/03/2021 8:40 pm
Lung
 Lung
(@lung)
RE: First assembly: Filament Sensor high-resistance
I had a nightmare trying to get the sensor on far enough to feed filament easily. In the end it was still ~5mm or so from the end but i couldn't get it any further in so gave up as it was working ok.
Publié : 16/03/2021 8:45 pm
aegixx
(@aegixx)
Same, the two tubes do not align very well, so getting the filament moving is definitely not easy.
Publié : 16/03/2021 9:53 pm
