Finally got a prusa. too bad i failed at putting it together
[Rozwiązany] Finally got a prusa. too bad i failed at putting it together
BulletShogun
(@bulletshogun)
two problems here. well the video show the major one. It keeps trying to go down off the bed.
pinda has been adjusted a few times. and it keeps crashing the bed for some reason. good news is i understand this is a user issue.
also for some strange reason i cant get the screws to fit in the end of the x axis tensioner.
Any ideas?
Opublikowany : 01/12/2023 10:23 am
_KaszpiR_
(@_kaszpir_)
RE: Finally got a prusa. too bad i failed at putting it together
what's the firmware version?
Opublikowany : 01/12/2023 7:25 pm
BulletShogun
(@bulletshogun)
turns out my stupid self didn't move the z axis when i should have. so yeah. me issue.
Opublikowany : 04/12/2023 7:26 am
René
(@rene-3)
From the looks of the video,
the Z column is mounted too far forward.
With a properly mounted Z column,
the distance is about 16.5 cm to the front
If the distance is less on your printer,
reassemble the z column according to the instructions in the assembly manual.
Step 46-47.
After reassemble the z column, you need to run the calibration wizard again!!
Opublikowany : 04/12/2023 9:56 am
If you have problems to assemble the Mini on your own, there is someone in your area who could help you - see https://world.prusa3d.com/en
wbr,
Karl
Opublikowany : 04/12/2023 1:29 pm
