Filament Loading and Z-axis issue
RHSwan
(@rhswan)
I bought a semi-assembled Mini+ and put it together yesterday and today.  I bought the filament sensor and added that as well although I had trouble inserting the PETG tube from the machine.  Everything tested well on the selftest.  I tried to load the PLA filament and the drive made a chattering noise.  I tried a couple more times and the same thing happened.  I turned the machine off and back on.  With the filament removed, I started to try and load the filament again, only it said the filament was already loaded.  I still tried to load the filament again and still had no luck.  (Yes I cut an angle on the filament).  I then decided to removed the filament sensor to simplify things.  I wanted to try to remove the cable from the Mini+ computer.  To get easier access, I tried to move the z-axis by hand, only I couldn't do it.  I could move the x and y axis but not the z.
Any ideas?
Postato : 08/05/2022 8:22 pm
https://help.prusa3d.com/article/extruder-noises_2013
There are a few possibilities but I suggest you start with gear alignment and idler tension.
Postato : 08/05/2022 10:39 pm
