Extruder Clog first PTEG print
lnjustin
(@lnjustin)
The filament stuck in the extruder after about 2 hours into my first PTEG print. To the point where I had to disassemble the extruder pulley and get the clog out. I hesitate to go at it again without addressing any underlying cause. Any suggestions on what might have caused this? Is this just a fluke or do I need to address something (heatcreap?) before proceeding with another PTEG print?
Factory assembled Mini+ only a few weeks old
PLA fine - have done numerous PLA prints without issue
for the first PTEG print, I set up a satin sheet profile and recalibrated first layer - had to go quite low on the offset, down to 1.95
printing with Prusament PTEG jet black
Respondido : 10/01/2023 9:58 pm
Hello
(@hello)
RE: Extruder Clog first PTEG print
kinda hard to tell if you only do one print might be a fluke
Respondido : 10/01/2023 10:05 pm
mark
 mark
(@mark)
Probably nothing to do with the clogging, but 1.95 is too low. You should readjust the Pinda sensor so it winds up about 1.0 so there is some room to vary. That adjustment is described here:
https://help.prusa3d.com/guide/height-adjustment-of-m-i-n-d-a-superpinda-sensor-mini-_154547
For the clog, adjust the extruder idler screw as found here:
https://help.prusa3d.com/article/idler-screw-tension_177367
You can also do a cold pull. In step 7, it should be pretty easy to push. If not, it may be clogged.
https://help.prusa3d.com/article/cold-pull-mini_126399
https://help.prusa3d.com/article/clogged-nozzle-hotend-mini-mini_112011
Regards,
Mark
Respondido : 11/01/2023 2:13 am
