extruder blockage problem
rjbram
(@rjbram)
Brand new (factory assembled) mini plus just received a few days ago. The first print was OK, but next several led to blockage of the filament extrusion. Seems to start out OK, but gradually the extrusion gets less and less and then quits altogether. Have to take apart the tubing and pull out distorted filament from above the nozzle. Ideas on what might be the cause? thank you.
Respondido : 05/06/2021 1:21 pm
Miembro
RE: extruder blockage problem
You have a partial jam to your nozzle.  You need to do a cold pull.
Respondido : 05/06/2021 4:50 pm
Miembro
Also, Check to see how tight you idler screw is.
Respondido : 05/06/2021 4:51 pm
rjbram
(@rjbram)
Thanks! I think that helped, it seems to be working better now.
Respondido : 05/06/2021 10:19 pm
Miembro
@rjbram
Make sure your nozzle is not too close to the bed.  That will start a path to under-extrusion.
Respondido : 05/06/2021 10:24 pm
